Page 17 of 23 FirstFirst ... 71516171819 ... LastLast
Results 161 to 170 of 223
Thread: my `76 GOLF 3dr
  1. #161
    Jun 2006
    Orange NSW
    I think my car's over heating because the thermo fan will go on after even a 5 min journey, in todays heat. like It wasn't that hot today, and I didn't go thrashing it (okay, i did, but like twice) and then once I go home, the fan started up. Just a concern I spose.
    Sounds pretty normal to me dude. My car has a diesel radiator (which has more surface area) and it does that. The reason it comes on when you turn the engine off is because the water stops cycling and the heat soaks from the engine into the water and trips the thermo fan micro switch.
    It's totally OK for that to happen they all do it. Actually most cars do it.
    You only need to worry if your temp gauge is going past about half way even when you are moving.
  2. #162
    Jun 2007
    Eastern Suburbs Melbourne
    ah righto. I see. Just me worrying I spose. Now i just gotta get the temp gauge fixed
    i like volkswagens
  3. #163
    Mar 2007
    Canberra
    Same with my Mk1. Most times when I get home the thermo fan comes on after I've switched off. Very normal.
    Good idea to get the temp guage working properly. Cooking an engine is not my idea of fun.
    Keen to see the car at the 'nats
    2010 Tiguan 125TSI
    2004 Polo Match
    1976 White MkI Golf
  4. #164
    Boronia VIC
    The thermo fan cycling on and off is normal. You're only doing short trips at low average speed and that doesn't give you enough airflow.
    When you need to worry is when the fan come on and stays on. Normally once the fan kicks in it only runs for a few minutes before the temp drops back down enough for it to turn off again.
    Sounds like it's working normally, when you hit the highways at 100Km/h you'll find it never kicks in at all. In the 'burbs it'll be cutting in and out all the time.
    You shouldn't need a sparky to fix that dash, just the reg or another working cluster will probably be cheaper. Do a couple of searches, those regs have been a topic on here before. I just used my last spare one to fix the same problem in one of my Golfs. They're dead easy to change over.
    Pete
  5. #165
    Jun 2006
    Orange NSW
    Just remembered, i've got 3 (count them, 3!) complete dashes at the workshop. Let me know if it's your temp gauge and not your reg and i'll hook you up. I think one of them has a tacho in it too, if you need/want one.
    Anyway if you need some stuff give me a hollar and i'll get the parts you want checked out.
  6. #166
    Aug 2006
    Melbourne VIC
    Hows things going
  7. #167
    Jun 2007
    hmmm....
    WOOT!!!
    i like volkswagens
  8. #168
    Boronia VIC
    Nice tyres those BF Goodrich's.
    Pete
  9. #169
    Nov 2005
    newcastle
    Thumbs up
    High Five!! :d:d
    TDI mk1 on the road!!
  10. #170
    Aug 2005
    Prahran, Vic
    good on ya. who put the plates down so far thou? looks like it sticks out over the edge a bit, or is that an illusion?
